Secondary air pump noise
Old Mar 1, 2009 | 05:22 PM
charcoal grey's Avatar
Default Secondary air pump noise
When first starting my 01 D2, the air pump is extremely loud. Once driving for 30 seconds or so it gets quiet. I took it to the dealer and they said since the pump was not bad yet they could not replace it under warrenty. Now that it is out of warrenty I am wondering if it is something that I should look into replacing. How does one test to see if the air pump is actually working? Although I also see air pump rubber mounts available. I am wondering if mine are bad. Dealer did not mention anything about those being bad.
Old Mar 1, 2009 | 05:29 PM
There is a filter to the air pump, check and clean it and see if that helps.
Old Mar 1, 2009 | 07:17 PM
I will check and clean the filter. I checked the mounts for the air pump and those were fine.
Old Mar 1, 2009 | 07:20 PM
I would think that if it were the mounts or tubing that it would be noisy all the time and not just when cold.
Old Mar 1, 2009 | 08:18 PM
humroot's Avatar
Mine is like that too. Been that way for years. It goes away after 30 seconds so I don't worry about it. I guess I should check the filter too.
Old Mar 1, 2009 | 09:37 PM
IDAHODISCO's Avatar
I cant find the air filter on my service manual is that under the hood?
I have 2000 discovery
Old Mar 2, 2009 | 02:59 PM
Mounts looked good. Filter was not too bad, but cleaned it with soap and water and let it dry. Still the same. I probably won't worry about it until it fails.
Old Mar 2, 2009 | 03:00 PM
Idaho, the filter is on the front of the pump itself. Just a plastic cap that covers it. Pops off fairly easily.
Old Mar 2, 2009 | 11:22 PM
khuds308's Avatar
ha! thanks guys. I think i have been haven this problem as well.
TRIARII
Sep 24, 2019 07:49 AM
jallert
Mar 3, 2010 07:28 PM
isofast
Jul 12, 2009 12:58 PM
jdelp
May 30, 2007 03:49 PM
akartis
Sep 25, 2006 01:31 PM
