secondary air system
Old Mar 25, 2024 | 07:44 PM
girouardrover's Avatar
Default secondary air system
Got a funny one - kind of
Does anyone know how I can by pass the secondary air system (SAS) on my 2003 Land Rover Discovery II HSE.
Meaning, the air motor is bad and not only is it hard to find one new - used or at all.
Since the motor is bad, it throws a SAS fault.
It is very expensive for something that only goes on for seconds and only at certain temps and times
Not to mention on my older rig not sure the SAS results in any benefit
Any ideas, advice, etc.?
thanks
Old Mar 26, 2024 | 07:18 AM
greggnvt's Avatar
Default SAI Delete
Search the forum for SAI delete - there has been tons of past discussions on this.
Old Mar 26, 2024 | 08:03 AM
mollusc's Avatar
I have one off my parts truck if you want it.
Old Mar 27, 2024 | 03:51 PM
sure how much?
Old Mar 27, 2024 | 05:22 PM
mollusc's Avatar
Say $25 plus shipping? Shoot me a message with your contact email. I can do Zelle or PayPal and should be able to get it sent this weekend.
Old Mar 27, 2024 | 06:44 PM
sure let's give it a try
my email: girouard5@comcast.net
not very tech savvy but can try paypal
Old Mar 27, 2024 | 07:25 PM
thanks everyone
yes, a lot on the SAI deletion
appears it will be expensive to remove it
new ECU, fuel pump, plug block hole, etc.
I want the SES light off but don't want to spend a lot of money getting it do to so
So, I will trade with MULLUSC for his used one
if it clears the light, yay
if I continue to have issues, I will take others advice and tape off the light but periodically check for codes to ensure other areas don't need attention.
Old Apr 1, 2024 | 02:46 PM
V50-M66's Avatar
I deleted mine (removed pump, valves, lines. Cut the fittings that go into the head, welded shut, screwed back in) and pulled the cluster apart covered the SES light with some electrical tape. Works fine, don't have to deal with it anymore, and no light (that I can see anyway). Doesn't impact anything, just won't pass emissions in a state that has it
FernanBM
Oct 15, 2012 08:01 PM
RANGER46
Nov 29, 2008 02:09 PM
korostik
Jun 10, 2008 06:20 PM
LRDKW
Feb 9, 2008 11:56 AM
miahman98
Jan 12, 2008 10:49 PM
