Series II TD5 will not start
Old Aug 21, 2007 | 03:41 AM
Irish Wil's Avatar
Default Series II TD5 will not start
Hello all.
Stuck in Far North Queensland, Australia,with an internet connection and a 2001 TD5 that will not start. Everything appears (dash lights),(and sounds) Ok while key is moved to position two on the ignition, then on trying to start the engine there is nothing. Engine does not turn over, total silence.
I am not the most mechanically minded but I would appreciate any input before I get towed to a Toyota lovin' mechanic. Only thing I have been able to do is visually inspect all the fuses, and they were all good. Car has gone from running fine to dead.
Any ideas?
Old Aug 22, 2007 | 08:27 AM
okdiscoguy's Avatar
Default RE: Series II TD5 will not start
Just so you don't get left hanging, most of the people on here are North American and we don't get the diesels...[&o]. Thought I would bump you up to see if anyone from afar might be of help.
Just my opinon, but I would check your battery and all of your connections
Old Aug 23, 2007 | 03:42 AM
djessopeng's Avatar
You may wish to try a UK based forum at difflock.com. Notso good as this one as all Land Rover topics are lumped together. However almost all UK Disco II's are TD5's so you may get some help.
Good luck
Jamie Telford
May 7, 2020 04:44 AM
pgaukroger
Feb 29, 2016 05:56 AM
chipha
Mar 24, 2012 09:55 AM
gambia
Dec 20, 2007 01:00 PM
trini defender
Defender
Dec 11, 2006 05:14 AM
