serpentine belt
Old Apr 6, 2011 | 07:08 PM
iownme's Avatar
Default serpentine belt
just looked on atlanticbritish for a serpentine belt, but they don't list one for a discovery 2....what gives?...different name perhaps?
ordered one from advance auto $31, anyone had any problems with theirs?
Old Apr 6, 2011 | 07:25 PM
Bundu's Avatar
Banned
Belt Polyvee - Find Belts, Hoses & Other Land Rover Parts at Roverparts.com
Old Apr 6, 2011 | 07:58 PM
iownme's Avatar
thanks bundu, heaven forbid i should do a search for "fan belt" or "sepentine"
after seeing your link, i did a search for just "belt" and it came up....internet sminternet...lol
Old Apr 6, 2011 | 08:32 PM
antichrist's Avatar
I always buy my belts locally, Goodyear, Gates or Dayco.
Old Apr 4, 2012 | 03:23 PM
WillRove's Avatar
Default Which Belt
I posted this in the wrong spot earlier.. how do I know if I need a belt with ACE or not?
Old Apr 4, 2012 | 05:41 PM
humroot's Avatar
If you have ACE, the belt will be longer to to turn the ACE pump. ACE is Active Corner Enhancement. Easiest way to tell if you have it is to look at your power steering fluid reservoir and if it has 2 caps, you have ACE.
Old Apr 7, 2012 | 03:10 PM
WillRove's Avatar
Default changed belt....
now disco won't crank up.. So my serpentine belt was shot to hell. I bought the belt and was able change it without incident everything is aligned and running the way the diagram shows. totally happy with myself I go to crank the car kup and well.. nothing.. it wont turn over at all.. HHHHHEEEEELLLLPPPP....
Old Apr 7, 2012 | 03:27 PM
jafir's Avatar
Is it in park? Any click when you turn the key on? Red LED "on" or "flashing" on the cluster? Power to the starter when you try to crank?
Old Apr 7, 2012 | 04:06 PM
WillRove's Avatar
Disco is in park. No unusual lights or anything. i get a clicking noise like i've heard when my alternator or starter has gone bad on other cars.
Old Apr 8, 2012 | 12:07 PM
You have a dead battery, take it out, go get it charged and tested. If it is bad buy a replacement with at least 800 CCA rating.
