Servicable U Joint Problem
So I'm about to replace the servicable U joints that I installed ONLY 6 MONTHS AGO (yup they're already failing), and I just remembered a problem I had with the neapco u joint recommended in the link below. The problem I had was that the clips were all too small! I had to use the original clips that came with the factory u joints. I can reuse them again I guess, but if I bend one or lose one I'm screwed. Anyone else have this problem? Any recommendations?
Meant to post these links
Link to the u joint recommended: Advance Auto Parts: Universal Joint by Neapco - Part 1-0005 Link to the rebuild "How To": https://landroverforums.com/forum/ge...rebuild-29302/ |
call lucky8.com ask for the lr ujoints for it they are 16 bucks each maybe? same part num as the defender 90 joints.
I think there was a bad batch at some point as I had several like that bought all at once. Went back to Advance and swapped them out for the correct snap rings.
I've never had one fail/wear out anywhere near that soon. Did you grease it properly before installing and again after? The grease that comes in u-joints is only to hold the needle bearings in place and to prevent rust. |
Originally Posted by grandkodiak
(Post 235527)
Made in U.K. - $18 |
indeed they do... and very friendly. i called up on a whim from work from my cell and ended up ordering 3 ujoints form them after finding out the local landrover dealer wanted $124.00 EACH. ended up returning them only because I actually ended up needing to replace the entire shaft (found it brand new on ebay $350), but they were very good quality from what i saw on brief inspection. they felt solid, there were few external deviations in shape/form, the needles looked very uniform and they just "felt" more solid then the ones i looked at at autozone.
(Post 235573)
Originally Posted by antichrist
(Post 235533)
And yes I greased them at every oil change. I think I may have missed one, so if that's the reason they went I'll take the blame....but I wouldn't think so.
your stock ones lasted 70000 without being greased at all, missing the new ones once or twice in the last 6-months is not the cause.
