service engine light on
Old Feb 11, 2009 | 01:11 PM
Earl Callow's Avatar
Default service engine light on
Good afternoon , being a newbie , Ihate to ask this question, I have 2003with 61,000 miles on it the service engine light just came on ,serial # is not within the oil pumprangeproblem, My question would be, what might be the main causefor this tocome on ? Any help would be greatly appreciated .
Thank you
Old Feb 11, 2009 | 01:25 PM
Default RE: service engine light on
Why not go get the fault codes read and get back to us with those 4 digit number, then we can help you.
Go to a local auto parts store where they may still read them for free.
Oh, and start reading your owners manual so you get a better idea what makes your truck tick.
Old Feb 11, 2009 | 01:39 PM
Thanks Mike, I will stopon the wayhome from worktonight and see if they can find out something and Iwill reply. I agreewithyou on reading up, just need to make time, work 10 hours a day plus1 hr drive to work everday , doesnt leave much time , but I WILL TRY
Old Feb 11, 2009 | 02:24 PM
I hear that.
Old Feb 11, 2009 | 04:42 PM
Mike , I just took it to Autozone ,the ran a check and it said emssions . Pretty vague , any ideas ?
Old Feb 11, 2009 | 04:48 PM
was running fine this moring , wonder ifI got some bad gas, I was thinking of getting a can of sea foam and adding to the fuel , cannot hurt
Old Feb 11, 2009 | 04:51 PM
service codes #P1412 & P1415
Old Feb 11, 2009 | 05:01 PM
In reading these posts , codes seem to be about vacuum pump.Anything a layman can look at and maybe fix ?
Old Feb 11, 2009 | 05:49 PM
ryanD2's Avatar
They are lean codes, meaning the computer is seeing more oxygen in the exhaust than its supposed to. Could be a simple vacuum leak, or an exhaust leak prior to the oxygen sensors. Could be the engine not dumping enough fuel into the engine, but unlikely. How mechanically inclined are you?
Old Feb 11, 2009 | 06:25 PM
I can fix alot of things.However Idont have any electronic gear ,do Ineed any? What do Ineed to look for? Loose hose? etc
