service engine light
got the codes read.
came up code P0501 if i remember right. anyway said error 02 bank 1
so i assume its a bad 02 sensor on bank 1, front.
one the way home i stop and get gas and drive a bit. next thing i know the light goes out. interesting,,,
i assume the sensor is going bad or the pigtail is loose or gummed up. i will clean it up and if the light pops up i know its failing.
thanks for nothing you jackals
When I saw your post this afternoon, I almost replied, "No the SES light is not going to pop on for no good reason. Get your codes read." But, I figured someone that's been here as long as you have would know that already
then i read the codes just in case and it came up with a bad O2 sensor. i got a fresh tank of gas and drove home and the light went out.
i love my rover. its self fixing hahaha
