Service Engine Light Blinks and I get all this codes for Autozone!!
Old Jul 20, 2008 | 06:50 PM
casanova00's Avatar
Default Service Engine Light Blinks and I get all this codes for Autozone!!
Ok...went to autozone and got all this codes
P1301 No description Catalyst damaging level of misfire detected on cylinder No.1
P1302 No description Catalyst damaging level of misfire detected on cylinder No.2
P1303 No description Catalyst damaging level of misfire detected on cylinder No.3
P1304 No description Catalyst damaging level of misfire detected on cylinder No.4
P1305 No description Catalyst damaging level of misfire detected on cylinder No.5
P1306 No description Catalyst damaging level of misfire detected on cylinder No.6
P1307 No description Catalyst damaging level of misfire detected on cylinder No.7
P1308 No description Catalyst damaging level of misfire detected on cylinder No.8
The service engine soon light starts blinking after I take off and the truck does not want to exceed 45mph. During the acceleration the service engine light continues to blink and only stops blinking but remains on is at an stop light. I was reading other threads and found out that the coils packs where a last resort and from other threads I am assuming it is a bad MAF! I appreciate all your help!!
Old Jul 20, 2008 | 07:08 PM
Default RE: Service Engine Light Blinks and I get all this codes for Autozone!!
STOP DRIVING IT!! When was the last time you had a tune up?
Old Jul 20, 2008 | 07:11 PM
2000 Disco 2 SD7's Avatar
It's your MAF most likely - I had the same problem and replacing it was the cure, though you may need plugs and wires.
Old Jul 20, 2008 | 07:12 PM
casanova00's Avatar
I did the tune up about 2 months ago or so!!!
You can get a MAF for $143 including shipping at : http://www.landautoparts.com/DIS003_2000_parts.html
Old Jul 20, 2008 | 07:15 PM
What brand of plug wires did you use? DI or DII?
Old Jul 20, 2008 | 07:17 PM
casanova00's Avatar
DII dont know the brand they where bought at advanced auto parts!!
Old Jul 20, 2008 | 07:20 PM
In case you aren't aware, K&N air filters will foul a MAF. Also (another just in case) open your hood in total darkness with your engine running and check if you see any arcing from your plug wires (could be the culprit).
Old Jul 20, 2008 | 07:22 PM
You need new plug wires. ONLY use Magnecor wires,...
Old Jul 20, 2008 | 07:23 PM
www.atlanticbritish.com, buy the Magnecors and then return the others for a full refund.
