Service Engine Light Codes p1172 p1175
Old Sep 29, 2009 | 04:21 PM
seamuspg's Avatar
Default Service Engine Light Codes p1172 p1175
Yesterday my service engine soon light came on so I went and got the codes read like you guys suggested on my 01 Disco.
P1172 and P1175
Can you guys shed some light on what they mean? I am not a wrench but hopefully i can answer any other basic questions you may have concerning my vehicle.
Basics--- I run premium grade. I add a fuel injection additive every 3k. Oil was just changed. Head gaskets have been replaced. Spark plugs replaced.
Old Sep 29, 2009 | 04:31 PM
hilltoppersx's Avatar
how many miles are on your truck. they are Oxygen sensor errors.
Old Sep 29, 2009 | 06:36 PM
seamuspg's Avatar
it just turned 75 k....
Old Sep 29, 2009 | 06:37 PM
malmberg's Avatar
I also had those exact same errors. Has your gas mileage been worse than usual lately? I replaced my MAF sensor but I have only put on 200 miles since with no SES light. There have also been a few others that have fixed this problem with a MAF sensor. Just remember to buy a factory one or the codes will return. Good luck
Old Sep 30, 2009 | 05:33 AM
seamuspg's Avatar
What is an MAF? something air-filter? How do you get the actual light to go off? Am i to assume that as soon as I replace the MAF it will no longer be lit?
Old Sep 30, 2009 | 06:13 AM
Roverpatsfan's Avatar
I had those codes and I replaced my MAF and 1000 miles later the ses is still off. You have to replace it, then have an obd scanner reset your light. Here is the one that bought.
http://www.roverparts.com/Parts/ERR7171G.cfm
Old Sep 30, 2009 | 07:18 AM
seamuspg's Avatar
is it bad to drive with those codes on? also how can I be sure that is what the problem is? 217$ isnt cheap right now...thanks for the advice
Old Sep 30, 2009 | 07:14 PM
seamuspg's Avatar
today i started the truck and the engine light was no longer on...do i ignore it and hope it doesnt come back? any reasons why it would do this?
Old Sep 30, 2009 | 08:57 PM
malmberg's Avatar
I had the same codes come and go for months. If I had the money I would have replaced the part right away. In my case the gas mileage was horrible. Now I have a quarter tank of gas left where it used to be empty. So for every four tanks of gas I get one free. If you think of it that way the part will pay for itself in a few months.
Old Oct 1, 2009 | 06:51 AM
seamuspg's Avatar
What does an MFA do? Does my car already have one? and if so am I to assume that it just is no longer working properly? how does it affect gas mileage so drastically? and is the gas mileage only being affected when the service light is on? what are the chances that I buy the part and the light still stays on? i just want a little more info before i make the next step...thanks
