Service Engine Soon Light on and motor misfiring
Old Jun 9, 2009 | 06:27 PM
richey50's Avatar
Default Service Engine Soon Light on and motor misfiring
Hello,
My sister's 2004 Disco has the Service engine soon light is on and I changed the spark plugs and the propblem went away, but I was informed that the light came back and the car is still misfiring like before I changed the plug and also when she starts the car it does not want to crank like it used to, it sounds like its going to die, last item she told me was that car shakes alot when she stops and idle. So please let me know if anyone knows what the proplem could be.
Thanks
Old Jun 9, 2009 | 06:34 PM
I would suggest you PM me your tele number ASAP and lets talk. In the mean time tell her not to drive it and ask if the check engine light is on, if it is, she needs to go down to a local auto parts store and get the fault codes read. Then get back to us with the 4 digit fault codes.
Old Jun 9, 2009 | 07:20 PM
She needs new plug wires, that is your problem.
www.apexperformence.net has the best price on the Magnecor plug wires that are highly recommended for LR's.
Old Jun 10, 2009 | 01:59 AM
richey50's Avatar
I will take it to Pep Boys and try to pull the codes and get to you guys, also the spark plug wires look brand new and I dont know if that would make any difference, once again thank you and I will get back to you guys with the codes.
Thanks
Old Jun 10, 2009 | 09:05 AM
Get us the code numbers and lets see what is happening.
Old Jun 10, 2009 | 09:29 AM
tailchaser0527's Avatar
Spike, how could you possibly have come to the conclusion that plug wires are the problem?? I agree that replacement plug wires are a good idea for maint. But they are not the reason for as many problems as suggested on this site..
Richey, get the codes read and get back to us. Also, how many miles are on the truck? A misfire can be the result of many different things, bad plug wire, coil, maf sensor, or coolant getting into the cylinder, along with tons of other things. having the cel codes will help us make an EDUCATED guess.. Instead of just throwing parts at the truck.
Old Jun 10, 2009 | 09:48 AM
richey50's Avatar
The truck only has 39k miles and I will try to get the codes today, thanks for all the help.
Old Jun 10, 2009 | 10:28 AM
What octane gas is she using??
Old Jun 10, 2009 | 11:22 AM
richey50's Avatar
I really dont know but knowing my sister she will use 87 because its cheaper
Old Jun 10, 2009 | 12:09 PM
Robmcin's Avatar
Uh-Oh!!!! You said 87 Octane!!!
