setting sls ride height
Thankyou in advance i have replaced ride height sensors on my td5, as the rear end dropped if parked on uneven surface also the where perished but it still drops, if its parked on even ground it very often stays up, i have seen on other forums the air bags get pourous so i have ordered a new pair the veh is 12 now, my local garage can re calibrate the sls but dosnt have the calibration blocks can anybody give me the dimensions of the blocks so we can make our own his system wont let his program go any further without them as it needs a zero point to proceed also should my veh have bump stops as i can find no mention of them in workshop manual thanks again in advance
![Confused](https://landroverforums.com/forum/images/smilies/muBAORM.png)
![EEK!](https://landroverforums.com/forum/images/smilies/bmHv6Xb.png)
To set up the sensors I would guess is not that easy and must be done on an absolutely 'board' flat and level garage surface with the LR unique kit and software program. I have never done this but I would be interested to see how you make out with it. Good luck.
bhorwhat
09-09-2009 06:41 AM
co556guy
04-04-2009 01:47 PM
MaxColee
10-06-2008 10:21 PM
Speed racer
09-09-2008 03:05 PM
