D2 fault P0722
Old Feb 20, 2014 | 08:33 AM
chipha's Avatar
8th Gear
Default D2 fault P0722
Hi good people!!
My D2 TD5 will not go forward! It will reverse though. Nanocom gives me a fault "Stall speed monitoring" have put a second of e-bay XYZ Switch, didn't help. Reading on forums I get a hint that it might be TC..but how come it can reverse and not go forward. Please help if anyone has come across this before. Thank you!!!
Old Feb 20, 2014 | 09:33 AM
DiscoJ's Avatar
actually, this sounds like it may be your tourqe converter.
Old Mar 4, 2014 | 07:13 PM
parkerlander's Avatar
did you get this figured out?
have the same code and tranny not responding in any gear after tcase swap......
Old Mar 5, 2014 | 11:18 AM
DiscoJ's Avatar
chipa's problem with only going in reverse sounds like a tourque converter since reverse is still usually operable whith a tourque converter failure.
parkerlander, you're issue soulds like your Tcase is positioned/stuck in neutral.
Old Mar 6, 2014 | 06:41 AM
chipha's Avatar
8th Gear
I actually I just change the T and it seems like it's working now. Even though I find the gear change from 2 to 3 takes a bit longer. But it's working all fine. So I reckon it must have been the TC
Old Mar 6, 2014 | 06:43 AM
chipha's Avatar
8th Gear
I meant to say I changed the TC(torque converter) and it's working now
Old Mar 6, 2014 | 05:38 PM
DiscoJ's Avatar
out of curiousity, did you change out the tourque converter yourself or did you have a shop do it?
if you changed it yourself, do you have any tips/advise for the rest of us that may be useful?
Old Mar 8, 2014 | 02:34 AM
chipha's Avatar
8th Gear
Well we did it from my house out of a car park. That's how things work in Africa. I probably know more about D2 than the garages out here. But not on my own, I have two trusted guys, mechanics, that I work with. I just tell them exactly what needs to done, thanks to Forums like this one.
I will sit down with my mechanic and write up a step by step process as to how they replaced the TC, then I will post it here. It takes them 6 hours to bring down the gearbox replace the TC and put the gearbox back up again.
happy1ff
Mar 8, 2019 02:58 AM
chipha
Engine & Internal
Feb 20, 2014 08:24 AM
06Range
May 8, 2013 09:01 PM
umoms
May 5, 2013 07:18 PM
