shock hardware failure
Old Jan 21, 2009 | 02:14 PM
franklips's Avatar
7th Gear
Default shock hardware failure
I have a 97 disco and I replaced my shocks about a year ago and just today I lost the bottom nut and bushings on my left front shock. So I was wondering what size nut I need to replace it with?Any help would be much appreciated.
Old Jan 21, 2009 | 03:33 PM
Default RE: shock hardware failure
I do not know what size they are, but if you go to www.roversnorth.com you can look it up.
Old Jan 21, 2009 | 03:37 PM
Landzu's Avatar
All shocks don't use the same hardware so it would be hard to know without
knowing the brand and then it will only be hard to be sure.
Home Depot sells nuts for .15 to .25 cents each you may just try your luck
and see or pull one off the other side and take it in.
Old Jan 21, 2009 | 03:47 PM
Before you go driving around looking for something that may or may not fit, what brand of shock did you have installed? Call the supplier and order what you need.
Wayne
Oct 2, 2020 12:10 PM
wblake
Oct 19, 2007 08:33 AM
ghinesley
Oct 4, 2007 03:54 PM
wrf
Jul 20, 2006 01:08 AM
