shopping for an alternator
Old Mar 13, 2014 | 12:56 PM
dougn's Avatar
Default shopping for an alternator
my (03 disco) alternator sounds like a box of rocks so I'm looking for a replacement. there seems to be two variations on this before and after vin 3A239592. what's up with that? does anyone have any suggestions for a good rebuilt or should I go new?
Old Mar 13, 2014 | 01:00 PM
dusty1's Avatar
mean green sells an upgrade version.
some say stay away from reman, but i have been running one from o'rielly for 3 years with no problems
Old Mar 13, 2014 | 01:36 PM
drowssap's Avatar
check for a RR alt. they are usually 50 amp's or so higher than disco alt.
Old Mar 13, 2014 | 02:38 PM
Dan7's Avatar
Universally stay away from "Rebuilt", which replaces the defective part only. "Remanufactured" replaces everything except the housing and other non-moving parts that don't really go bad. Not sure which one O'Riley's sells.
Old Mar 13, 2014 | 06:20 PM
jafir's Avatar
You can use a 1999-2002 alternator in a 2003-2004 or the other way around.
You can get the older version in a brand new Bosch on amazon for pretty cheap.
If you search this forum you'll probably find a link to it. I think it's around $200.
Old Mar 13, 2014 | 08:57 PM
jfall's Avatar
Get a brand new DENSO.
Don't get a Bosch.
NOTHING REBUILT. NOTHING.
Agree on the Range Rover greater AMP alternator.
Old Mar 13, 2014 | 09:00 PM
jafir's Avatar
Bosch is OE in this application. That and Valeo.
Old Mar 13, 2014 | 09:48 PM
Madlands's Avatar
https://landroverforums.com/forum/di...roblems-57950/
I've had way too many issues with rebuilt as seen in this thread. Shop amazon for a new Bosch. Hopefully you can find one there.
Old Mar 13, 2014 | 11:17 PM
jfall's Avatar
Ouch. I stand corrected. And that's fine.
I guess Denso was OEM on my Discovery I.
I never replaced the alternator on the D2.
The previous owner did!
I escaped that bullet.
Old Mar 14, 2014 | 12:15 AM
zeroone's Avatar
Thanks for that madlands.. I never gave amazon a thought. I've got bad bearing screams coming from my alternator. Not to mention a very curious(and dirty) decal that says LAND ROVER on it and a very odd manufacture date.
