Short in dash when using blinker?
Old Jun 4, 2009 | 09:32 PM
Night Train's Avatar
This is what you need to fix pesky blinkers
Product Name- Price
Blinker Fluid $8.99
Old Jun 4, 2009 | 09:45 PM
AK Rover's Avatar
I thought his problem was being caused by the blinker fluid leaking in to the instrument panel and causing a short.
Old Jun 5, 2009 | 07:26 AM
Damnit - I missed that, so what he really needz then is a can of Anti-Short!
Old Jun 5, 2009 | 04:37 PM
Disco Fuego's Avatar
No leak in the blinker fluid... I power washed the instrument panel last week and still no traces of blinker fluid, so I am cool there...
Old Jun 5, 2009 | 05:34 PM
So I read it wrong. Last time I towed my trailer my light would flash then go off even though all my lights work. I wonder if the LED turn signals screwed with the circuit
My trailer lights ground wire gets corroded all the time, once I cut it and re-ground it the trailer on the dash blinks.
Old Jun 5, 2009 | 06:34 PM
Is there a difference between when the trailer is plugged in and not? I have not pulled a trailer with this truck yet...
Old Jun 5, 2009 | 06:39 PM
The little trailer light on the dash blinks once when you use your turn signals and NO trailer is connected to the trucks wiring via a trailer wire harness.
When a trailer is connected to the truck with a trailer wire harness the little trailer on the dash will blink in unison with the trucks turn signals, it does this to let you know if your trailer lights are working or not.
Old Jun 5, 2009 | 06:45 PM
so I do have a problem cause mine blinks in unison without trailer attached. Oh well, no biggie! Thanks for the detail Spike.
Old Jun 5, 2009 | 07:55 PM
AK Rover's Avatar
Yes, it is my understanding that if it continues to blink without a trailer attached you have a problem.
Old Jun 6, 2009 | 11:55 AM
JBEGIN's Avatar
mine blinks and so doesnt everything else when i use my left directional
Ive replaced all kinds of fuses, checked my battery , had my alternator tested,
checked grounds, cant figure it out
