Should I be concerned?
Old Aug 24, 2010 | 10:58 AM
joatman's Avatar
Default Should I be concerned?
I swapped wheels and tires last week. I also had the diff fluid changed. Past few days I've noticed some leakage on the rear passenger wheel.
Is this something I need to be fixing quickly, or do I just have a seal going out that I need to start thinking about replacing?
-Aaron
Old Aug 24, 2010 | 11:36 AM
sloan74's Avatar
Where is it leaking from? The brake or the axle seal? Can you get some pics behind the wheel? Diff fluid will leak a tad when flushed, if he filled it to the top it will dribble out the fill plug. But it would only dribble down the diff case cover, and only a sprinkle - not spray out the opposite side and thru the tire rim like in your pic. Is it all wet inside the wheel (other side)? If so, that has to be brake fluid be my guess..or rust maybe? Maybe it's just rust/dirt and crap from inside the wheel hub? Wipe in with your finger, what does it smell like? That pic could just be showing that?
Edit - yeah it looks to be that looking a the pic more, the way it sprayed from the wheel hub out.
________
VAPORIZER INSTRUCTIONS
ems12
Dec 12, 2014 02:07 PM
dusty1
Off Topic
May 7, 2014 03:28 PM
green_
Dec 15, 2012 11:02 AM
Livingintheskies
Aug 9, 2011 02:40 PM
RoverR
Nov 2, 2010 09:11 PM
