Should I or shouldn't I?
Old Oct 19, 2006 | 07:10 PM
Godsson314's Avatar
5th Gear
Default Should I or shouldn't I?
Okay I ran into a 94 Discovery. it has 126k on the dash, pretty good shape for about $2,000.
I wanted to have something for the winter to park my existing car. I like the style, it is different and I heard they are great in the snow.
The concerns:
I was told there is
- a oil leak (not that concerned it is a beater, or should I be concerned?)
- coolant leak (a lil more concerned)
-leak coming from the differiential box.
Is this something that would be okay to do, or should I run fast and far away
Thank You!
Old Oct 19, 2006 | 07:19 PM
allstarbiker592's Avatar
Default RE: Should I or shouldn't I?
The coolant leak could be coming from the head gasket which is about 600 to replace.
Old Oct 19, 2006 | 07:20 PM
Godsson314's Avatar
5th Gear
is that something that can be driven while not functioning properly?
Old Oct 19, 2006 | 07:22 PM
Ya you can still drive it. You will just have to keep adding coolant.
Old Oct 20, 2006 | 12:42 PM
Godsson314's Avatar
5th Gear
Any other tips or suggestions?
I really need some imput looking at the car today.
Thanks
Old Oct 20, 2006 | 02:17 PM
For a winter vehicle, you should be fine, may do a couple repairs if needed but I wouldn't woryy about the oil leaks, can you see where th coolant is leaking from?
Mike
Old Oct 20, 2006 | 02:40 PM
Godsson314's Avatar
5th Gear
No I have not really been underneath the car...it was too dark to see.
Old Oct 20, 2006 | 02:43 PM
Godsson314's Avatar
5th Gear
Are there any things I need to look out for in this car....something that typically always breaks?
Thanks!
rmace1
Mar 3, 2012 09:25 AM
MrBrooks
Jun 14, 2010 09:45 AM
DaRedFox
Freelander
Feb 19, 2008 01:22 PM
DaRedFox
Nov 19, 2007 02:44 PM
Coppi
Mar 24, 2007 09:55 PM
