shuttle valve ???
Old 07-18-2009 | 03:32 PM
sloppyjoe's Avatar
Default shuttle valve ???
what are the symptoms of a bad one?
Old 07-18-2009 | 03:35 PM
3 amigos
Old 07-18-2009 | 03:48 PM
sloppyjoe's Avatar
well yeah,,,
but i mean is there a feel in the brakes or something you can feel in the brakes,,,
Old 07-18-2009 | 03:55 PM
I have no idea, I know that it can set them off but I think the only way to know is if it throws the shuttle valve code which I dont know what those numbers would be.
What is she doing? Do you just have Chevy, Martin and Steve on your dash?
Old 07-18-2009 | 04:04 PM
sloppyjoe's Avatar
feels as if the brakes transfer power from the rear to only the fronts. its a odd feeling
Old 07-18-2009 | 04:08 PM
Hummm...feels like all fours are grabbing then all of a sudden it only feels like the fronts are working...maybe the shuttle valve.
Have you flushed the brake fluid on this thing yet?
Old 07-18-2009 | 04:32 PM
sloppyjoe's Avatar
yeah it feels like all 4 grab and then it suddenly transfers to only the fronts.
i was gonna flush and bleed and see if that helps.
Old 07-19-2009 | 10:11 AM
The front brakes on all vehicles are designed to have more stopping power. Are your 3 amigos on, are your brakes squealing? If you throw a panic stop, when the 3 amigos are on, can you feel the ABS pulsate thru the brake pedal?
Old 07-19-2009 | 10:44 AM
But you are forgetting Mike that LR uses equal brake force distribution, meaning that equal braking power goes to all four wheels at the same time.
Thats why there are 4 brake lines coming out of the shuttle valve not 2 like most cars where it gets split at the axle to go to each wheel.
It is also known as 4 channel braking.
Old 07-19-2009 | 10:51 AM
But they don't, and I am trying how to best describe how the system works.
Yes there are 4 lines from the master cylinder to the module and 4 out but the module does not regulate the pressure, just the activation.
If you think about it, you always go thru about 1/5 sets of front brake pads to 1 rear set, the rear pads and rotors are smaller then the front. I am going to get some more specific information and get back to you.
Take care,
Quick Reply: shuttle valve ???
