Signs of excessive front diff or R&P wear....
Old Jun 8, 2015 | 05:25 PM
dz5bxm's Avatar
Default Signs of excessive front diff or R&P wear....
So the new family battle wagon, aka "Blue" has one hell of a drivetrain rumble from 40-70mph. It sounds like a worn wheel bearing but is only present under load, silent during coasting and decel. No distinguishable variation in noise while turning.
Certainly not the front driveshaft, it's brand spanking new. Rotated 180 for ****s in giggles and no change in harmonics.
Why do I think front diff or R&P? Since none of the receipts showed diff fluid change, I changed them when I first got it this spring. Front diff/R&P had tons, and I mean tons, of shavings and half the fluid had a nice metallic shear. R&P seem to also have excessive rotation before teeth engagement, roughly 30-40 degrees. Mileage is 116K, so it's possible.
I'm finally tearing down the 2000 so I'll compare the R&P action on that one this week. Right now I'm thinking of swapping entire diff to compare if the rotation before engagement seems tighter. May even replace the hubs with some cheapo chinese units since I'll have them out anyways.
So my Q, anyone have similar woes? Seems like 116K is low for such excessive R&P wear, but you never know how it was used.
Old Jun 8, 2015 | 09:31 PM
Alex_M's Avatar
I saw something similar in my rear (the play and metal shavings, not the oil). Then again, when I changed the oil there was a decent amount of water in the oil that I believe caused the issue. I would consider that an excessive amount of wear, but I don't have a ton of R&P experience.
Old Jun 9, 2015 | 06:17 AM
drowssap's Avatar
you can just pull the axle and hubs as a units and just slide the newer diff in place.
those off-shore hubs if the have taylor number are just fine.
Old Jun 9, 2015 | 08:11 AM
ZGPhoto's Avatar
Like Drow said, you could always replace the diff. Marty sells them for like $70 shipped...
Old Jun 9, 2015 | 12:33 PM
RegT's Avatar
I have a similar issue and have been debating how to handle. My Diffs are pretty clean now but when i bough the truck it had alot metal on the magnet and was a black with bubbles. That was 22K miles ago (she has 117K now). Changed it twice since then 80/140 and its clean now but i still have the same whine and rumble. Thinking just replace the diff, not sure who Marty is but will give him a call just let me know his details, I am sure he is on here and i will recognize him with his user name.
Old Jun 9, 2015 | 02:39 PM
drowssap's Avatar
Check the parts section for a guy drillbit "i" think it is
Old Jun 9, 2015 | 06:01 PM
dz5bxm's Avatar
thanks for the insight - I will do. I'll update the group on how it goes.
Old Jun 9, 2015 | 06:13 PM
dz5bxm's Avatar
so after looking - it appears just pop the two ball joints and pull...seems like a simple first step - better than wrestling with the hubs - they never come out easy, but always go in nice.
Old Jun 10, 2015 | 07:02 AM
drowssap's Avatar
4 bolts and the hubs and axle slide out.
Ranu2222
Apr 13, 2015 08:04 AM
RITTER
Aug 24, 2012 03:16 PM
BabyNurse
Mar 2, 2011 08:23 AM
wolfgang528
Defender
Dec 28, 2010 04:25 PM
krhodes
Aug 28, 2009 05:08 PM
