Silicone hose kit!!!
After many countless hours of searching only to come up short or find a place that doesn't ship internationally, I finally found a company that has the full silicone hose kit with bleeder screw for the factory v8 cooling system. The color is blue so it should match my plug wires n boot covers!!!! Base price is still cheaper than any aftermarket kit over here.
The following 2 users liked this post by Luckyjayb:
BhamRover2002 (03-10-2017),
JUKE179r (03-08-2017)
I thought so especially since the specs look great on it. Here they are specs. I especially like the temp range.
- High quality silicone rubber construction.
- Smooth easy clean finish.
- Manufactured to fit as per the OEM equivalent, no modifications required.
- Working temperature range from -50°C to 220°C.
- 5mm thick wall reinforced with 4 polyester / nomex mesh layers to withstand higher pressures than your original rubber hose.
- Fits as a direct replacement for the OEM black hoses that are prone to cracks and leaks.
- This is an ideal way to dress your engine bay.
- Manufactured to a very high standard.
- We recommend this item is fitted by a professional mechanic to ensure the correct fitment
