SLABS ECU Issue-Sub-system controls
Old Aug 30, 2008 | 10:21 PM
ronthepoet's Avatar
Default SLABS ECU Issue-Sub-system controls
I've been trying to get my ECU to fire the SLS compressor, and thinking it was the unit needing to be reset. (Trip to the Stealership-OUCH!)
HOWEVER!!!
I noticed (when it was operational) the unit would stop when the door opened, implying other sub-systems that controlled the power-on function of the leveler.
Then, as I was locking it up, the horn beeped. The ONLY time this has happened in the past (and it happened every time) was when a door was left ajar. This led me to think that one of these sub-systems may have decided to go at at this particular time, thereby following Murphy's Law of Land Rover Ownership.
Does anyone know what subsystems (in addition to the "door ajar" phenomenon) have this effect on the SLABS or SLS system? Also, where the possible fault(s) may lie?
Ron
Whatever the Human mind can conceive and believe, it can achieve.
(Mark 11:24)
Old Aug 31, 2008 | 12:52 AM
Urban Panzer's Avatar
Default RE: SLABS ECU Issue-Sub-system controls
Ron, I know you have SLS issues, and Im sure it will get sorted somehow, However, Posting 4 different topic / titles for the SAME thing does not really help, and will not get you an answer any quicker......... Keep all your posts under the same topic, its far easier then for fellow users to follow your progress.........
and to reset your SLS ECU, You will need to visit a dealer, or an independant that has Rovacom or Testbook diagnostics.....
Just for info, the SLS compressor will not run until ALL doors are shut, and the engine is running...(unless you have a remote fob for trailer connection.)
Old Aug 31, 2008 | 08:12 PM
Darover's Avatar
There was a dealer recall for the slabs ecu, I had mine done 2 years ago. You should check to see if yours has ever been done.
lrjon
Dec 18, 2013 02:52 PM
tbarton
Jul 6, 2013 02:39 PM
Patrick Duffy
Nov 16, 2012 05:17 PM
MarvelVT
Dec 26, 2009 10:29 PM
ronthepoet
Aug 30, 2008 08:57 PM
