Sleeves
Old Apr 12, 2018 | 02:42 PM
2Guinness's Avatar
Default Sleeves
I have my motor out and am looking for a machine shop to install sleeves. I am not interested in 2200 dollars for top caps, just the standard sleeve which will last another 100K most likely. Anyway, can anyone recommend a machine shop in Northern Arizona or Southern Utah? I have tentatively settled on Reynolds Motor Machine in St. George Utah but it is a 3 hour drive from Page AZ. I was hoping someone has had experience with a shop and can make a recommendation.
Thanks,
Chuck
Old Apr 12, 2018 | 03:08 PM
Sixpack577's Avatar
Are yours out of spec?
Are you concerned they are slipping?
Old Apr 12, 2018 | 04:03 PM
2Guinness's Avatar
I have had two sleeves rattling about for some time. Finally I noticed a head gasket leak at the number 6 cylinder with associated water spray, Upon disassembly I found a pressure leak at the inside of number 5 cylinder. So the sleeves are slipping and need to be replaced. The upper end was rebuilt 3 years ago by the previous owner..
Old Apr 12, 2018 | 04:39 PM
CollieRover's Avatar
i’m no Engine builder, but you can have sleeves pinned I believe.
Old Apr 12, 2018 | 04:43 PM
2Guinness's Avatar
HMMM do you mean pin the existing ones? That is interesting.
Old Apr 12, 2018 | 05:16 PM
I have no idea, but a shop would.
Old Apr 12, 2018 | 06:42 PM
Sixpack577's Avatar
I pinned mine a few weeks ago.
Several people have.
We followed the "how to" thread here.
Easy with the engine out, still doable with it in.
Old Apr 12, 2018 | 06:47 PM
Sixpack577's Avatar
Some sleeves slip, and only make noise, hitting the bottom of the head gasket.
Others, that leak coolant between the sleeve and block, may only be fixed by top-hat liners that have o-rings, to hold back the coolant.
So, if it's just noise, pin them.
A Land Rover Master Tech that posts here confirms it works, and has done it.
Old Apr 12, 2018 | 06:57 PM
I wish I had had this option, but the old block cracked, and I can’t say I am disappointed in my Turner with the cam though.
Old May 31, 2018 | 02:51 PM
2Guinness's Avatar
I pinned the sleeves and the noise completely disappeared, but unfortunately the number 6 cylinder is still leaking water. Can the block be repaired or do I have to do the 4K dollar dance.
