slight vibration and possible chirp under acceleration
No problem. Don't take a chance driving it if it's the driveshaft chirping. Hopefully you will be able to center lock it, remove the shaft, and drive it while you are waiting on your parts.
If you can't center lock it just park it till you can fix it. UJ's are cheap, transmissions are not.
and be sure that whatever u-joints you buy are greasable and grease them at every 3K miles or so. The grease bakes out.
i triple checked the front shaft again...trying as hard as i could to shake it to test the three joints-it did not move at all. could the chirping and rattling be from something else? i understand the front shaft needs to be rebuilt but i'm worried there is something else causing the vibration. I havent heard the chirping in a while.
