Slightly off topic... need advice on a good grease gun
Old Sep 22, 2012 | 09:41 PM
primussucks's Avatar
Maybe it is the end piece on mine, but it seems to snap on the fitting just fine, but getting it off is a nightmare. I sometimes have to get pliers to yank it off.
Old Sep 24, 2012 | 01:41 AM
bootzilla's Avatar
I have a cheap Harbor Freight one. Works just fine, and I've had it for a couple of years.
I second the flexible hose thing - mine has a rigid nozzle, and it is a pain. Next time I'm at Harbor Freight, I'll pick up a cheapie with a flexible nozzle.
Old Sep 24, 2012 | 07:22 AM
drowssap's Avatar
Prematex also sell preasurized grease in a 6 in. can with a flexible hose, kind of looks like fix-a-flat. it good to have kicking around in the travel tool box.
Old Sep 24, 2012 | 07:34 AM
antichrist's Avatar
If you want a manually operated gun (which I prefer because it's not dependent on anything that might die, like batteries) there are two main types.
Pistol grip that has a max psi of about 6,000 that can be used with one hand and lever type that has a max psi of about 10,000 that requires two hands to use. Both of mine are lever type, one a 40 year old Plews and the other a Lincoln that's about 5 years old. The newer Lincoln actually seems to be of better quality.
Flexible vs rigid tube. On the pistol grip the flexible tube will work fine, however on the lever type if you have any flush style zerks you want a rigid tube.
Old Sep 24, 2012 | 11:33 AM
grandkodiak's Avatar
Old Sep 24, 2012 | 11:35 AM
bballjames's Avatar
Originally Posted by grandkodiak
That is awesome... too bad they didn't have one like that at AutoZone on Saturday when I was there...
Old Sep 24, 2012 | 12:19 PM
Gotta go to one in a bad neighborhood and ask the warehouse guys in the back
Old Sep 24, 2012 | 07:43 PM
You can buy just the flexible hose, its like a nickle, unscrew your rigid one, screw in the new one.
MarkSF
Mar 4, 2014 11:31 AM
Love U Landie
Feb 4, 2013 03:17 PM
Disco_Fever
Jun 15, 2009 09:49 PM
Disco Fuego
May 8, 2009 07:48 PM
okdiscoguy
Feb 6, 2008 03:03 PM
