Slipped Liner 4.6
Old Mar 9, 2020 | 10:07 PM
piperff's Avatar
Default Slipped Liner 4.6
Liners Pinned , so far no Issues..#7 cylinder slipped ...Did a Engine rebuild..with pinning ...all went well....Had a soft tick after break in ,turned out to be rocker shaft Oiling holes upside down, replaced Rockers and Shaft...Engine is Running Quite...Since this was done in the Spring of 2019..have added 8,000 miles...
Posted a few pictures in Gallery...
Old Apr 5, 2024 | 08:08 PM
Hughesy1961's Avatar
Hi,
I am looking to pin my liners and wondering about how long this fix lasts. Not that much recent info on the longevity of the pinning fix. How is yours going? Also I could not find your photos in the gallery. Did you follow the set screw method 1/4" set screws with high temp Loctite?
Old Apr 6, 2024 | 03:03 PM
Harvlr's Avatar
I think they last a long time
Old Apr 6, 2024 | 04:21 PM
Extinct's Avatar
done correctly it should be a permanent fix
Old Apr 6, 2024 | 09:56 PM
99TEXASD2's Avatar
Here is the guide I followed...hope it helps anyone that needs it down the road
File Type: pdf
Old Apr 6, 2024 | 10:47 PM
Thanks I have found this guide as part of previous research and it is a good guide. I have a P38 and am planning on doing the job in the vehicle so need to remove the exhaust manifold, starter motor, mounts etc and use a right angle drill. Hopefully on my Right Hand Drive car I will not have any access issues on the RHS!
Jason428sc
Apr 23, 2020 09:03 AM
D24.6
Mar 24, 2019 06:48 PM
Mr. Tick
Feb 22, 2018 11:37 AM
discoIIfever
Apr 3, 2017 08:43 AM
Dane!
Feb 5, 2014 09:32 PM
