Sloppy steering question
Old Nov 23, 2021 | 05:00 PM
me 2's Avatar
Default Sloppy steering question
Just curious, I have tried adjusting the steering box with no luck, replaced Front Steering Drag Link & Track Tie Rod Bar, wheel bearings, front ball joints but still feels like Carnival cruise handling. If I replaced the steering box, steering column shaft and pump would that fix my issue? Not sure what else to do! Thanks for any suggestions
Old Nov 24, 2021 | 12:55 PM
11chuck's Avatar
I'd check to make sure the 41mm(?) drop arm nut is tight as hell and the securing washer folded properly, along with the steering shaft u joints being in good shape and bolts tight on the spline clamps. Beyond that, box replacement is the only option. Once the box goes bad, no amount of adjusting will fix it.
Pump wouldn't cause looseness, so if it's good it's not necessary to replace unless you decide to replace whole system just for the hell of it. If you do replace it, don't buy a cheap off brand one. The one I had was dead on arrival due to horrible machining tolerances on the back plate causing binding of the internals which destroyed it. I got a reman from Cardone and while I haven't used it yet it seems to be much better quality.
I just went through this whole ordeal myself on my 02 and replaced the box with a good used unit from an 03/04. The boxes are actually different part numbers and there are slight differences, but they interchange without any issue. Box replacement is pretty simple and straight forward at least. Just takes some muscle to move them heavy things.
Old Nov 24, 2021 | 02:49 PM
cvhyatt's Avatar
I went through this nightmare as well but my steering box was leaking like a sieve and I had sloppy steering. First I tried the Blue Devil stop leak but that didn't fix it. Then I bought a used steering box to save a few bucks which lasted about a month before it dumped fluid. Then I bought a refurb from rockauto for $400. It leaked as well so I sent it back for a replacement. Third one has held up for six months so far.
One thing to note, if you do this yourself, get ready for some serious wrenching. Most of the replacement units that I have seen don't come with a drop arm so you need to transfer the old one to the new. You need a large puller, 41MM socket and one heck of a breaker bar. Ask me how I know!
https://landroverforums.com/forum/di...44/#post770583
Old Nov 26, 2021 | 11:10 AM
Tomzsix's Avatar
I am having a similar issue. does anyone think that the cv joints would cause the problem?
Old Nov 27, 2021 | 01:00 AM
JohnZo's Avatar
CV joints won't cause steering problems. There are good video tutorials on line that walk through steering checks for land rovers, mainly involving one person rocking the steering wheel while another person watches the steering linkages.
Old Dec 10, 2021 | 12:25 PM
Westminster02's Avatar
I had a similar troubleshooting run down as you and the U joints on the lower steering column had loosened up on mine. Probably won’t completely fix it, but at least for me, tightening those back up helped. All the slip joints and u joints on that shaft add up to a lot of little potential places for steering slop.
Old Dec 10, 2021 | 12:33 PM
me 2's Avatar
Good to know guys! I am going to replace the control arms with corrected ones and a adjustable pan hard bar since I have a 3" lift.
Old Dec 11, 2021 | 10:39 AM
RVA560SEC's Avatar
4wd High
I think that is the real answer here. From all that I've read, having the castor correct arms makes a world of difference at 3" lift and above. I personally would start there and see if you're happy with it.
Old Dec 11, 2021 | 07:36 PM
The_OGCJR's Avatar
well now that you’ve said that, you should’ve done the caster arms first. Then start diag the rest if you still feel like it’s bad
Old Dec 13, 2021 | 08:28 AM
TimInNova's Avatar
These seem to be the best deal out there:
https://rtefab.com/product/offset-radius-arms/
The RTE's are $200 less than the Terrfirma ones:
https://www.roverparts.com/suspensio...us-arms/TF529/
