Slowly leaking coolant...
Old Nov 6, 2009 | 02:04 PM
blcp86's Avatar
Default Slowly leaking coolant...
My disco has been slowly leaking coolant and I am pretty sure, judging by what I have read on here that it is the heads...so now my next question is I found the head gasket kit on AB for 160, which doesnt seem too bad, but how meticulous is the actual job itself? I've been through the entire 60K myself...but not sure if this is over my head or not...any advice would be great. Thanks.
Old Nov 6, 2009 | 02:09 PM
lipadj46's Avatar
Is it leaking on the outside or the inside? If outside have you found where it is leaking from? I did my head gaskets with no experience just following the Rave CD. It was nerve wracking but worth it. I would say though make sure it is you head gaskets and not somewhere else.
Old Nov 6, 2009 | 02:43 PM
If you have some skill, you could do it yourself.
You will also need new head bolts, a new t/stat and the up-graded upper radiator hose that has the bleed screw built into the black plastic"TEE".
Old Nov 6, 2009 | 02:52 PM
blcp86's Avatar
It is leaking on the outside...I will try and get a picture of it so you guys can tell me what you think...its dripping straight down onto the front axle
mike...when you say an upgraded upper hose, im not sure exactly what you mean...i also have an 03 disco, and that bleeder looks like a T i guess...is this what you are talking about?
Old Nov 6, 2009 | 03:01 PM
We don't need a picture, just a specific description of where the coolant is flowing from off the block.
OK, sounds like someone has already up-graded your upper hose then.
Echoman
Dec 17, 2014 01:38 PM
zski128
Jun 29, 2013 11:22 AM
DiscoSlat
Nov 11, 2012 09:42 PM
jamiederr
Oct 31, 2010 03:00 PM
whurst79
Jun 1, 2008 07:13 PM
