Drive train problem
Old Nov 6, 2009 | 03:09 AM
lsi's Avatar
lsi
3rd Gear
Default Drive train problem
Hi.I hope someone can help me.
I have a 1998 Disco I with +-200000 km on the clock.It is a manual V8.
About 2 weeks ago it started making a clacking sound underneath the car.
I checked under the car and could not see anything broken.The front propshaft has a bit of a play on it.Able to turn it about 3cm either way.Is this supposed to be like this.
This only happens when I accelerate,if you leave the gas it quits down.
I also saw that if I engage the diff lock,the noise also stops.
How can I check if this is CV's,propshaft,U-joints or Transfer case?
Any help appreciated.
Thanks
Armand
Old Nov 6, 2009 | 03:33 AM
AK Rover's Avatar
Sounds like a bad u-joint. Mine did the same thing when my rear most u-joint was failing.
Old Nov 6, 2009 | 03:04 PM
There should not be any movement in the u-joints. How often do you grease them, if not often then replace all 3 or 4 u-joints cause the rest are probably going bad from lack of grease.
DiscoJon
Jul 14, 2019 01:51 PM
hubris
Dec 14, 2007 09:31 PM
s2_lwt
Jan 14, 2007 07:41 PM
BridgeRover
May 17, 2005 02:03 AM
Big boy
Mar 25, 2005 10:08 PM
