SLS Air Spring Problem
Old Oct 12, 2012 | 03:11 PM
ZGPhoto's Avatar
As long as you carry a spare than it's all good. Are you at stock height or do you have a spacer under the bag?
Old Oct 12, 2012 | 03:17 PM
wreckdiver1321's Avatar
I'm in the process of putting a 2" lift on it. Already have the OME springs and shocks, but I had a bit of a hiccup with the original company I ordered the spacers from, so I ordered a set of spacers from RTE today. Replacing the bag just now because it leaks and I don't want to burn up my compressor from running it so much.
Old Oct 12, 2012 | 05:44 PM
Okay, so I've learned my lesson. I bought a cheap air spring. One that didn't connect to the factory air line using the factory fitting. After attempting to do it the way they instructed, I've had the air line leak, the spring exploded, and now i'm finding it very difficult to get the truck off jack stands. looks like I need to track down a Hi-Lift to make it work. Now to do some research on getting factory air lines.
jdg52
Nov 19, 2010 10:42 PM
southfloridadiscoII
Jun 18, 2009 08:48 AM
humroot
Nov 27, 2008 01:26 PM
landbeater
May 5, 2007 01:24 PM
