SLS Air Suspension
Old Dec 2, 2005 | 01:10 PM
pbcarter66's Avatar
Default SLS Air Suspension
I have a '99 Disco II and the rear air suspension does not work. Yesterday the compressor would not shut-off even when turning off the ignition. I had to pull the fuse to get it to stop. I removed the two lines that come from the air valves and no air is coming out, even when the compressor is running, but it does come out of the middle line which supplies air to the valve block.
Could this be a bad SLABS ECU? As I recall the compressor should not run with the ignition off (normal ride height mode)
Old Dec 3, 2005 | 06:59 PM
mikemeyer0's Avatar
Default RE: SLS Air Suspension
coil conversion.
Old Dec 4, 2005 | 08:11 AM
Randy Lover's Avatar
the compressor does work with the ignition off i think as you can purchase a key fob with the controls for the SLS on it, ideal for hitching up a cvaravan etc.
OffroadFrance
Mar 10, 2014 12:17 PM
cptshanman
Sep 4, 2012 02:19 PM
Allan John
Jul 10, 2012 08:31 AM
Allan John
Jul 6, 2012 01:59 PM
buick215
Jun 17, 2011 01:31 PM
