SLS Air suspension problem
Old Jul 6, 2012 | 10:21 AM
Allan John's Avatar
4wd High
Unhappy SLS Air suspension problem
Can some please advise me on my SLS problem?
I have a 2004 Land Rover Discovery; three years ago I had both air bags replaced.
For the past six month when I turn off my engine, I have been experiencing my offside rear dropping down to the bumstops,
This only happens within five to ten minutes after I have turned off the engine and never at any other time. I can restart my engine and the suspension re inflates to a normal level.
This problem only occurs about once a week or once a fortnight.
Due to this problem been intermittent my Land Rover garage are unable to find out the cause.
Has any one else experienced this problem or explain what the fault is?
Old Jul 6, 2012 | 10:44 AM
Who's bags did you install 3 years ago?
What your describing is going to be either a air leak at the bag, bad height sensor or an internal ECU issue.
If you want more help, send me your number and I'll call you back.
Old Jul 6, 2012 | 12:47 PM
Allan John's Avatar
4wd High
Mike.
The air bags were fitted by my local Land Rover Garage, as I said three years ago.
After spending some time looking on the net, my idea was that I had a faulty height sensor.
But thought I would try and get some more information from people like you that know a great deal more about the Disco then I do.
Would the garage be able to check for any fault codes? Or is that not possible on my Disco 2?
So may be I should get the garage to first check the bags and then check to sensors and replace any faulty parts.
Old Jul 6, 2012 | 12:53 PM
Most shops will not be able to scan the SLS system, takes a special scanner to read the codes.
Let me know if you want to talk.
Old Jul 6, 2012 | 01:27 PM
Allan John's Avatar
4wd High
Mike
Will a Land Rover garage have the correct equipment to test my SLS for faults?
Old Jul 6, 2012 | 01:38 PM
Allan John's Avatar
4wd High
Mike
Allan
Old Jul 6, 2012 | 01:59 PM
You will have to call them and see, some of those scanners and the necessary software is pretty expensive.
OffroadFrance
Mar 10, 2014 12:17 PM
cptshanman
Sep 4, 2012 02:19 PM
Allan John
Jul 10, 2012 08:31 AM
buick215
Jun 17, 2011 01:31 PM
pbcarter66
Dec 4, 2005 08:11 AM
