SLS to Coil Conversion
Old Oct 22, 2010 | 09:05 AM
timmay7t's Avatar
any help on which specific fuse or relay needs to be removed?
Old Oct 22, 2010 | 09:39 AM
Sounds like you haven't even looked yet, that being said, there is one fuse in each fuse blocks, look on the back of the covers and locate them.
Old Oct 22, 2010 | 10:32 AM
NiteTrain's Avatar
ahhhh bottle jack! that's what I should of used instead of a spring compressor...very good write up...needs to be in the sticky section.
Old Oct 22, 2010 | 10:54 AM
timmay7t's Avatar
i immediatley went out and pulled them after my post. thanks for the follow up! i hope it solves my battery issue
Old Oct 23, 2010 | 07:09 AM
vandev's Avatar
Default this will help
My daughter had a battery drain for over a month and couldnt figure out..finally pulled all compresser connections in the compressure housing...it wa s the problem. Disconnect all wires in the SLS box underneith on drivers side..
Chris
Old Oct 24, 2010 | 06:10 PM
caiogaucho's Avatar
In my case, solved. Only the panel light stays lit!
Old Nov 1, 2010 | 08:14 AM
timmay7t's Avatar
same here !
Old Oct 16, 2011 | 02:07 PM
jayzoid's Avatar
Great How To!! I was wondering about the removal of the ride height sensor in step 11. If I have ACE does this ride height sensor also work with ACE or is okay to remove it? Thanks!
Old Oct 17, 2011 | 06:47 AM
drowssap's Avatar
I believe the ACE system uses two sensors but they are diferent and mounted up high near the top of the truck, so that they can react with the roll immediately.
Old Oct 17, 2011 | 11:52 AM
Leave the height sensors alone, they won't hurt any thing or just remove them.
