SLS Conversion
Old Feb 24, 2012 | 09:19 AM
If you still have my number, we should talk, looks like you don't have a direction yet.
Old Feb 28, 2012 | 09:42 AM
brigadier_dj's Avatar
Well friends...it's done!
About 4 hours and we're back to freeway speeds, finally!
After getting under there and checking out the compressor, I really do think replacing the fuse could have handled the problem, but I like the ride and it future proofs any further issues that might arise.
It also gives me some confidence in my ability to do the lift in the future.
Mike, I will be in contact this Spring, probably. I'll have some money then..haha
Old Feb 28, 2012 | 10:14 PM
ssblast20's Avatar
Guys - a follow up question to this post. I did the conversion months ago, and had a battery drain but recently figured (from reading on here) that I needed to disable the compressor. So, I pulled the main fuse and relay from the fuse box under the hood, which were obviously marked, and disconnected the two wiring plugs from the compressor, but now when I drive over 10mph, I get a constant "ding ding ding ding" the entire time I drive, and the suspension light is on. I could not take that annoying sounds anymore so plugged the two plugs back in (fuses out still) and the noise goes away, but suspension light still on. I looked at other posts on here and have not seen anyone report this issue?
Old Mar 14, 2013 | 01:18 PM
One year later: no problems still.
AK Rover
Sep 6, 2009 09:09 PM
robdis96
Jul 21, 2009 08:53 AM
humroot
Nov 27, 2008 01:26 PM
landbeater
May 5, 2007 01:24 PM
