SLS Conversion battery drain
in my 2001 it doesnt work. the sine on the worning lights teh sine indicating tail is high comes on and when go over 30kph the beeper warning starts to sound. if i lower the speed lower than 30kph the beeper stops.
Any other sugestions.
THANKS
THANKS
in my last post i didnt identify the car. its a discovery2 2001 that is discharging the battery after i change the suspension from airbags to coil springs. i disconected the hearth terminal and now its indicates high suspension in the dashboard lights. when i go over 30kph the beeper starts souding,
No solution in disconecting the earth terminal.
Any sugestions?
THANKS
Any sugestions?
THANKS
did that on my 2001 Discovery 2 and it didnt work, a lite of high suspension in the dashboard comes live and when i go over 30kph the beeper sounds like it has the suspension in high position.
Any other sugestion?
Thanks
Thanks
i tried to disconect the negative earth for the sls wich is beside the lead earth to the battery and it didnt work. the dashboard light for the sls comes alive as soon as you start the engine and the warning beeper starts sounding has soon as you rich 30kph. had to reconnect the earth again,
Did yousolve the problem already? and what did you do?
cheers
joao matos
cheers
joao matos
didn`t work in my 2001 discovery td5
