SLS Conversion battery drain
Old Jan 26, 2024 | 02:08 PM
  #21
joao matos's Avatar
did that on my discovery 2001 and has he r go over 30kph the beeper starts beeping, if i go under 30kph the beeper stops. doesnt work.
Old Jan 26, 2024 | 02:14 PM
  #22
joao matos's Avatar
in my 2001 it doesnt work. the sine on the worning lights teh sine indicating tail is high comes on and when go over 30kph the beeper warning starts to sound. if i lower the speed lower than 30kph the beeper stops.
Any other sugestions.
THANKS
Old Jan 26, 2024 | 02:49 PM
  #23
joao matos's Avatar
in my last post i didnt identify the car. its a discovery2 2001 that is discharging the battery after i change the suspension from airbags to coil springs. i disconected the hearth terminal and now its indicates high suspension in the dashboard lights. when i go over 30kph the beeper starts souding,
No solution in disconecting the earth terminal.
Any sugestions?
THANKS
Old Jan 26, 2024 | 03:00 PM
  #24
joao matos's Avatar
did that on my 2001 Discovery 2 and it didnt work, a lite of high suspension in the dashboard comes live and when i go over 30kph the beeper sounds like it has the suspension in high position.
Any other sugestion?
Thanks
Old Jan 26, 2024 | 03:40 PM
  #25
joao matos's Avatar
i tried to disconect the negative earth for the sls wich is beside the lead earth to the battery and it didnt work. the dashboard light for the sls comes alive as soon as you start the engine and the warning beeper starts sounding has soon as you rich 30kph. had to reconnect the earth again,
Did yousolve the problem already? and what did you do?
cheers
joao matos
Old Jan 26, 2024 | 03:45 PM
  #26
joao matos's Avatar
hello
did that and didnt work.
Any more suggestions?
Old Jan 26, 2024 | 04:21 PM
  #27
joao matos's Avatar
Can you tell me what kind of machine did you use to program sls to springs convertion?
Thanks for reply.
Old Jan 26, 2024 | 05:23 PM
  #28
joao matos's Avatar
Default didn t work in my 2001 discovery td5
Originally Posted by mln01
Here you go. It's connector C0811.
Originally Posted by thegails
The ground attached to the nut itself is the fuel pump. Nice coat of liquid electrical tape on the SLABS ground terminal and a wire tie to hold it down... no more dead battery.
Thanks all!
didn`t work in my 2001 discovery td5
Old Jan 27, 2024 | 01:05 PM
  #29
St1ck's Avatar
Originally Posted by Disco Mike
Pull the main fuse and relay in the engine compartment.
fuse for the SLS not the main engine fuse right?
Old Jan 29, 2024 | 12:29 PM
  #30
joao matos's Avatar
Hello.
I have a 2001 discovery2 and need to reprogram The slabs ecu,
Can you tell me what machine you refer and the version off software version is it?
Thanks for cooperation.
Joao Matos
