Small coolant leak
Old Apr 14, 2008 | 07:48 PM
Berryman's Avatar
4th Gear
Default Small coolant leak
I just bought 02' Discovery and I'm smelling coolant after I shut it off. I noticed the drip is coming from the top of the transmission bell housing. Could someone lead me the right direction where this is coming from?
Old Apr 14, 2008 | 08:50 PM
Default RE: Small coolant leak
Did you buy it from a dealer? If so take it back.
Most likely the valley pan gasket or ahead gasket.
Old Apr 14, 2008 | 09:10 PM
I agree, if not then go find a shop that can pressure test the coolant system to find the exact leak, most likely going to be head gaskets.
Old Apr 14, 2008 | 09:48 PM
wooz797's Avatar
do the d2's have the coolant lines that flow through the throttle body?
Old Apr 14, 2008 | 10:37 PM
okdiscoguy's Avatar
yes, there is a kit to fix it as well.
Old Apr 15, 2008 | 09:28 AM
If the t/body heater unit is leaking, it would be dripping on the drivers valve cover, not down onto the tranny.
Old Apr 15, 2008 | 09:39 AM
WolfPack's Avatar
well that's unfortunate...someone just unloaded a blown disco on you.
Hopefully you got it at a good price [&o]
Old Apr 15, 2008 | 10:43 AM
No, it could be, if he is luckey, a failed valley pan gasket, it can leak coolant also from the back of the engine.
Old Apr 15, 2008 | 02:42 PM
Urban Panzer's Avatar
Just done this on my D1 v8, coolant leaking onto the bell housing at the back. My first thought was head gasket, but simply climbed on to the engine with it running, and with a torch and mirror, looked down the back where youcan easily see the headgasket join with the block and my leak was higher up, and it was the intake gasket that had failed on the rear left corner when standing in front of the car.
Incidently, the gasket was modified at some point from a metal "crushable" type to a fibreglass / synthetic one. Total parts including all new bolts was around £35 or $70 ish to you guys.
Took about 5 hours in total to do
Old Apr 18, 2008 | 06:40 PM
Berryman's Avatar
4th Gear
I can't see anything. Too cramped even with a 24' flex light and mirror. Any tips to try to visually inspect it. It doesnt seem to want to leak all the time?
