Snapped Rocker Cover Bolt?
Old Mar 28, 2015 | 07:25 PM
robert.juric's Avatar
Unhappy Snapped Rocker Cover Bolt?
I have a leak around my rocker cover gaskets and I took the advice to try and tighten the bolts first. According to the rave it said to tighten to 3nm and then a second round to 8nm. I set my new torque wrench to 26in lb and started to tighten the bolt, I heard a snap and I thought this was the click that I reached torque. So I did the other bolt, same snap. I adjust my torque wrench to 70in lb and when I tried to tighten further it just spun. Got that sinking feeling in my stomach right now...
Now I'll admit this is my first time using a torque wrench, but I never heard a click, just the snap. Is this even something that's possible/probable? I suppose I'll be replacing those gaskets sooner rather than later...
Old Mar 28, 2015 | 08:16 PM
Its possible are you sure your torque wrench is a in lbs and not ft lbs?
Old Mar 28, 2015 | 08:27 PM
That's what I thought at first, but I triple checked, the settings on the wrench itself are in lb.
Old Mar 29, 2015 | 06:06 AM
drowssap's Avatar
Did you check the calibation on the NEW torque wrench before using it?
Old Mar 29, 2015 | 07:14 AM
No there were no calibration instructions except to take it to a qualified technician every 6 months.
Old Mar 29, 2015 | 07:19 AM
dusty1's Avatar
I like to check them against one another (torque wrenches)
You can get stainless Allen head replacement at v8tuner
Old Mar 29, 2015 | 07:48 AM
So I guess my question is what's next? What would be the best option for extracting the rest of the bolt? What would happen if I crank the vehicle (to move it into the garage) with 2 bolts not securing the rocker cover?
While I'm removing the upper intake and rocker covers is there anything else I should do while I'm at it?
Old Mar 29, 2015 | 08:14 AM
dusty1's Avatar
Crank it and move it. It will leak a little maybe
Take the covers off and see how much is there to grab a hold of. If that doesn't work go get some left hand drill bits or extractor and zip it out with a drill
Old Mar 29, 2015 | 08:49 AM
drowssap's Avatar
the worst that will happen is you will have a bigger leak than you started with, you will probably have to drill a hole in the bolt and use an ez-out.
by the way; truth be told first time i used a torgue wrench i snapped a head bolt, so dont fell bad
Old Mar 29, 2015 | 11:19 AM
ralphobell's Avatar
Hope you didn't use a harbor freight one...those things never are correct. I purchased two from Lowes that are Kobalt brand. Work great and the last two times i had them calibrated they were still spot on.
HF ones snapped my tranny pan bolt. Used a screw extractor and it came right out.
