snorkle set up question
Rovers North. For awhile they had Free UPS ground shipping...but there was an extra charge on heavy weight items, and for some reason this is a heavy item.
I wonder if Lucky8 could hook us up with a deal like $325. If a group buys buys 4 or 5.
RAISED AIR INTAKE DISCOVERY II
that would be cool. $450 + shipping is a hard trigger to pull
lets try to do it before spring hits cause the water will be high and I want to go out and play in it........
There are a few other areas of the intake you will need to seal up if you plan to dunk your Disco. The flexible area that runs to the air box is not waterproof, nor is the air box lid, and the air box itself on the bottom side has a water drain, and is also not waterproof. You will need to go through your complete intake and seal everything up tight if you plan on getting in real deep....
And with a gas engine anyway if you go to deep and stop you are done no matter how waterproof your airbox is.
This is with no snorkel or anything.
http://www.youtube.com/watch?v=_tQ2Tp3u_f8
grandkodiak
09-11-2011 05:20 PM
