So I broke my coolant bleeder screw
Old Apr 27, 2011 | 07:43 PM
DiscoRover007's Avatar
Default So I broke my coolant bleeder screw
So I over tightened the screw like a newb because it was seeping coolant when I was looking at it. I know that some people have replaced this screw through BMW. However I was wondering if I should be able to find something at a hardware store?
What would be the odds of my local LR dealer having them in stock? What if i came to a BMW dealership? Whichever way I can replace this fastest is my option right now.
Thanks as always
Old Apr 27, 2011 | 07:58 PM
Many people have used a screw from the hardware store.
Old Apr 27, 2011 | 08:21 PM
buick215's Avatar
Since you have to replace it you might as well go with this brass one. BMW Brass Coolant Expansion Tank Bleed Screw (Various Applications See List) : Bimmerzone.com It will probably never give you any more problems and doesn't cost to much more.
Old Apr 27, 2011 | 08:23 PM
NiteTrain's Avatar
be careful it's very flimsy..I broke my screw AND then the plastic threads inside. I rigged a rubber plug that worked fine but eventually bought a new hose.
Old Apr 28, 2011 | 01:42 AM
discoboy's Avatar
I ordered 2 of those brass bleeder screws others have mentioned here, I would say don't do it. I installed mine, making sure the o ring was intact. Was good for 3-4 days, then while checking oil, I noticed coolant spray marks around hose at brass fitting. I suspect the brass screw doesn't work very well with plastic, changed it back to the plastic. 500 miles later, no problems. Just my .02
Old Apr 28, 2011 | 06:57 AM
jeffh's Avatar
I had a similar problem a few months back..search for "bleed screw screwed me" I used a metric bolt I had for a while then ended up with the brass piece as well as replacing the whole upper hose assembly. As you cannot but the connector piece solo. I felt since the original screw had broken with the threads in and then after extraction I used a "closely" matched metric thread bolt I had It was in my best interest to ensure the Brass screw had the best possible threads to work with. I have had no issues since and that was way back in January...
Old Jul 23, 2011 | 06:06 PM
FNCROVER's Avatar
3rd Gear
BMW part # 17-11-1-712-788 VENT SCREW is the same part...$3.32.
My LR dealer & BMW dealer are owned by the same person, next door to each other.
LR parts mgr said LR doesn't sell the parts separately, must buy the complete hose assembly. I walked next door with the broken screw and it fits & works perfectly.
You can't use brass with the plastic T fitting, must use the plastic screw. Go to BMW and buy a couple to toss in your trunk.
Old Jul 23, 2011 | 07:36 PM
bosshogt's Avatar
My Brass screw has been on for about a year now. No problems. I thought about using teflon tape but thought I would let the O-ring do its work. No leaking on mine. I have a spare T and plastic screw if I have problems, but none are anticiapted.
Old Jul 23, 2011 | 09:58 PM
souljad9's Avatar
While bleeding air from my system, I lost my bleed screw. It fell, and I couldn't find it in my gravel driveway. I picked up 2 from the local BMW dealership for $5
kpl1228
Nov 25, 2011 08:45 AM
03discoman
May 9, 2010 09:46 PM
99discoverysc
Jan 12, 2010 05:43 PM
coloboy
Sep 6, 2009 12:19 PM
jim jones
Nov 18, 2007 06:59 PM
