so what'd I break?
so what'd I break?
Hi Folks,
I was working on the truck (2003 Disco) and I had the passenger side kicker panel off to run a wire in behind it and I was also
"groping" around pulling off the two leads from the cigarette lighter to tap in to it for a switched 12v source for something.
I didn't take apart the dash because I could get my fingers up in there to pull off the pos and neg leads on the cig lighter.
I got them back on and the lighter socket is working fine and so is the thing I'm powering, that's all happy but for some reason
now I have no white dash lights at all. I did check the dimmer control and its not stuck.
Any guesses what fuse I should look at for the instrument cluster? The clock has a burned out bulb so I KNOW why that
ones not working, do you guys think its a fuse or a connector that maybe I bumped or something?
The headlight are fine and so is the heater and odometer green backlights, its just the white dash back lights that disappeared.
Cheers'
Dave
Cheers'
Dave
so now what ?
Hey!
So a bit more digging - the fuse for the interment cluster is supposedly # 3 according to Rave.
When I turn the arm switch from off position 1 to 2 the # 3 fuse shows power going thru it but
the cluster is still not lit. Turn the switch to off and the current thru 3 goes off.
When I turn the light switch ON from position 2 to 3 headlights are OK so power shows up on:
Fuse 9 - Headlight Normal Beam - LH
Fuse 10- Headlight Normal Beam - RH
Pull the arm forward to switch to high beams:
Fuse 5 - Headlight High Beam - LH
Fuse 22- Headlight High Beam - RH
They're happy too and all the turn signals are ok and working. (Fronts, Marker and Rear)
Does anyone think I bumped a connector under the dash down by the cig lighter or is there
a wiring harness in behind the kicker panel under the glove box maybe?
Cheers'
Dave
Cheers'
Dave
yep, I agree ..... then what?
Hey abran,
Yep, I hope you're right ..... it just seems odd that the interment panel lights would die after I was working on it the dash area?!
There are no white backlights anyplace dash or shift console ...... No lights on P R N D but you can see the gear selection on the
green odometer screen anyway.
All I have I lit is the green odometer and the heater display panel even the backlights on the the heater buttons are dark.
Pretty weird! Does anyone know if there is there a way to check if the lighting switch in the control arm coming off the steering
column is working OK? Can I pull a harness connection someplace and put a continuity tester across a few pins to check the functioning
of the switch somehow?
Cheers'
Dave
Cheers'
Dave
echoes_and_fractals
08-27-2006 11:11 AM
