Solved: P0441 After new purge valve, and SAI pump coming on while stopped
Old Jan 27, 2013 | 06:12 PM
Jared9220's Avatar
Default p0441
I'm leaving this forum and have deleted all my work in this thread.
Old Jan 28, 2013 | 08:23 AM
grandkodiak's Avatar
I dont have an exhuast leak but occassionally the pump turns on for no apparent reason while comming to a stop, usually just kicks on for a second then off, or just pull forward a bit and it goes off. I attribute it to an unknown wiring issue somewhere. my old pump did it, the new one does too. from time to time i jiggle all the wiring around under the hood and various symptoms go away, some new ones appear lol. my biggest one was the rear harness t connector on the passenger side, some wires in there were rubbing or grounding on one another so bad i had popped fuses and all sorts of engine codes appear. jiggling the wires and opening the t connector solved the problems for over a year and a half before i had to jiggle them again haha
Antmen
Jan 11, 2020 06:52 PM
austinlandroverbill
Apr 1, 2015 06:26 PM
RANDY04D2
May 30, 2014 12:53 PM
roverbob
Sep 2, 2012 08:34 PM
masism
Jan 26, 2010 07:07 PM
