Some ideas about a leaky PAS pump
Old Aug 1, 2009 | 07:04 PM
lipadj46's Avatar
Default Some ideas about a leaky PAS pump
When I did my Head Gasket I had to remove the high pressure line from the PAS pump. Now I have a tiny leak there, but enough to let air into my system and eak a few drops overnight. My question is how can I stop this leak? It is in there as tight as its going to be without breaking the connector. I see there are 2 nuts on the line next to each other not sure if there is a way to adjust this connection. Or should I try a new line with connector?
Old Aug 1, 2009 | 08:26 PM
grussell's Avatar
There is an o-ring on each end of the hose on the connector that could have been damaged when you took the hose off and reassembled or is worn out.
Old Aug 1, 2009 | 08:39 PM
lipadj46's Avatar
I could not find one at the usual sites. Is that a specific O ring you can buy or do I need to pull it out and go buy an o-ring at home depot?
FlyingZebra34
Apr 18, 2014 02:00 PM
tigertrakstar1
Mar 5, 2014 04:13 PM
caleb
Dec 8, 2009 10:36 AM
willmjck
Oct 4, 2009 04:13 PM
elguappo999
Nov 10, 2006 09:08 PM
