Some sunroof tips
Old Apr 17, 2011 | 12:15 PM
Livingintheskies's Avatar
Default Some sunroof tips
So my front sunroof has given me tons of grief, stuck my radio on country helped along the death of my headliner. At one point after taking down the head liner fixing the drain tubes and still finding a leak after reinstall I considered for just a second....sealing it with epoxy....but no i really liked it.
I posted a thread of how I was going to re-drill tube holes and run new lines....bad day.....haha. Yesterday after more rain I decided to inspect the seal closely and after watch the actions of the rear roof over a few times found the front seal to be a bit squished on the left side.
Using my old transmission gasket (cleaned) and razor blade to trim it flat. I laid it under the sunroof gasket with some clear caulking and checked to make sure everything mated together nice and tight and rained like a mother last night. The inside of my truck finally was bone dry. Now you could use any thin waterproof material I used that only because I hadn't thrown it out yet for whatever reason and there was no other use for it. That and I couldn't find a new sunroof gasket ANYWHERE online and didn't see the point of hunting for another used in a junkyard as it would probably just leak again IMO.
Anyway the moral of the story is....be more patient and take some closer looks haha. Good luck to anyone else fixing this problem and you use this solution AT YOUR OWN RISK. Don't tell me how you used too much caulking and sealed your sunroof shut haha.
Gerard
Dec 31, 2024 11:30 PM
iplayblues4u
Jan 10, 2012 05:27 PM
humroot
Dec 13, 2010 07:47 AM
tads
Oct 10, 2007 08:48 PM
kelandra
Dec 22, 2006 10:43 AM
