Sound behind instrument cluster??
Have an odd sound coming from behind the dash just left of the instrument cluster.
The sound resembles a faint fuel pump or vacuum pump sound.
Once the key is turned to position 2 on the ignition switch you can hear it. That being said, it must be electrical but not sure what component would cause this sound.
It's the interior air temp sensor and it's part of the climate control, it has a little fan that pulls air past a temp sensor and feeds that information to the automatic temp control. It's located behind a little grille on the left side of the knee pad next to the dimmer control. Mine was noisy and I took it out and cleaned all the gunk out of the fan (just like my computer cooling fan). Here's a link with pictures of when I cleaned it. https://landroverforums.com/forum/di...-sensor-50556/
The instructions on how to remove it is in RAVE
It's more than just a fan, it also has a temp sensor built into it. I doubt that Radio Shack will match that. It's not a cooling fan, the fan draws air past the sensor for the automatic temperature control (something DI's don't have). If you don't want the irritating noise, just unplug the sensor, the fan will quit turning and you won't have automatic temp control. Not entirely sure how that will affect the operation since I've never tried this.
