Is this sound an exhaust leak?
Old Dec 25, 2024 | 11:47 PM
evil_goat's Avatar
Question Is this sound an exhaust leak?
I attached a video of the sound the engine makes on idle. It kind of makes a sound like those old muscle cars. Maybe an exhaust leak? It sounds louder from underneath the car and the drivers side. I also have a pending code for oxygen sensor circuit malfunction, but for the opposite side pre cat sensor. It remained after replacing the O2 sensor, but is pending now instead of confirmed. I tightened the exhaust manifold to head bolts, but I'm not sure if it made a difference in the noise. What could be causing the noise? It has made this ever since the engine rebuild that I have recently done.
File Type: mov
Old Dec 28, 2024 | 01:03 AM
evil_goat's Avatar
The "lopey idle" sound
in the old muscle cars is caused by valve overlap. My discovery makes a sound at idle that seems kindof similar, but much less prominent. It also is quieter as the car warms. When I rebuilt the engine, I replaced one of the heads, It was at or maybe a little outside the tolerance for the amount of material you can take off the head when resurfacing. In theory this would make the valves stay open longer and may create valve overlap. It also seems this sound is louder on (or coming from) the side of the replaced head. Is this what is happening? Would this cause anything bad to happen?
Old Dec 28, 2024 | 07:25 PM
Extinct's Avatar
Just an exhaust leak, do the leaf blower/show vac test.
Old Dec 28, 2024 | 11:19 PM
JohnZo's Avatar
About resurfacing the head, there is a simple way to re-adjust the valves to get back in spec. Insert shims under the rocker shaft pillars, equal to the amount taken off of the head. The shims need to be the correct shape in order to work with the oil passages. Not sure who sells them, try Rovers North maybe. Not installing the shims can cause problems if the lifters are compressed during all four strokes.
Old Jan 12, 2025 | 01:03 PM
evil_goat's Avatar
I got the fancy remflex gaskets extinct recommended. Would it be bad to put rtv on it as well?
Old Jan 13, 2025 | 04:39 AM
Extinct's Avatar
Not really needed but a thin coat would not hurt anything
sdjp
Dec 6, 2022 09:02 AM
LR03NJ
Sep 15, 2016 08:19 PM
99Discovery
Jul 20, 2016 09:34 PM
4x4ron
Sep 3, 2012 09:57 PM
thegails
May 30, 2012 05:16 PM
