sound of trickling water
Hi all,
Got kind of a weird issue: there is a trickling water sound inside my 2001 Disco II. It is pretty faint but clear. It is most pronounced when accelerating and going around corners. The carpets aren't wet. We have been having a pretty wet, cool summer up here.
Any ideas what might be going on?
Thanks!
Thanks!
Sounds to me like you have air in your coolant system you have to get all the air out. Follow this thread for instructions. https://landroverforums.com/forum/sh...ad.php?t=23072
Hi all,
Thanks!
Thanks!
I have had the same problem with air in the coolant system and it eventually burst a hose, the one with the 4 way coming off of the t stat. I am trying to figure out how air got in the system in the first place. This is the second hose that it burst. Bleeding it does some good for a awhile then it seems like pressure is building back up in the hose. I am suspecting a hg leak. Let me know your thoughts on this.
stormtrooper LV
DSII 197,000 miles
replaced front prop shaft
new coolant recovery tank
modified TB heater hose and radiator hose
New Alternator
replaced TB heater plate kit (2 x)
Replace Serpentine belt
all of the scheduled maintenance including the transfer gear box oil fill up
branman, Has the engine been overheating? After I fixed a bad water pump mine wasn't until it pressurized the cooling system and blew that same hose off.
You may want to look into getting a kit to do an exhaust gas test on your cooling system. If you've blown that hose off something isn't right...just having air in the cooling system probably shouldn't build pressure like that unless something else is going on.
Glad I stumbled into this thread earlier today! I thought the waterfall was just a land rover thing. . . A/C refrigerant or something liquified in this cold weather (bought my D2 last week). I also thought my coolant was full.
Nearly a full gallon of peak later, I realize I was making the old assume saying a reality. Thanks guys, you probably saved me from a very costly lesson!
