Sounds like a chicken clucking, coming from under the front
Old Mar 2, 2014 | 07:44 PM
MarkSF's Avatar
Default Sounds like a chicken clucking, coming from under the front
I can only hear it at low speeds, a sound like a chicken when it's strutting around the farmyard... Cluck... Cluck cluck..... Cluck. Only when the car is cold, it seems to go away after a while.
Seems to be coming from under the front of the car..... Could it be the front driveshaft? It's an 04 with 75k miles.
Old Mar 2, 2014 | 08:48 PM
coors's Avatar
Remove the prop shaft lock your center diff and go for a drive. That;s the only way to diagnosis it. Process of elimination.
Do you see grease fittings on the u-joints? This will tell you if it's been serviced or replaced.
Old Mar 2, 2014 | 08:59 PM
MarkSF's Avatar
No there are no fittings on the shaft, pretty sure it's original to the car.
Old Mar 2, 2014 | 09:20 PM
schwaggy's Avatar
I find it surprising that you've posted here 71 times but you haven't yet read about replacing the drive shaft. It literally comes up every day.
Yes, I'd start with the drive shaft as being a serious front runner for solving this issue. If you're going to take it off and engage the CDL to test, you might as well rebuild it or install an aftermarket one. Gonna need it regardless.
Old Mar 2, 2014 | 09:59 PM
MarkSF's Avatar
I have read about the driveshaft, that's why I asked if it sounds like that.
Old Mar 2, 2014 | 10:39 PM
dusty1's Avatar
uhhhh, did you check for a chicken, under there?
Old Mar 2, 2014 | 10:54 PM
xxdoylexx's Avatar
yep that is what it sounds like
Old Mar 2, 2014 | 11:12 PM
MarkSF's Avatar
Very carefully, yes. Could have used it for dinner tonight, had to settle for spaghetti bolognese instead. Must have escaped on the highway trip home!
Old Mar 2, 2014 | 11:56 PM
dusty1's Avatar
could (and prolly is) your shaft. but if you can hear it at idle (slightly raise rpms) choke that chicken ....................spray some wd40 (or the likes) on your pulleys, 1 by 1, till you find it. the lube will briefly silence the cluck, if that is the egg.
Old Mar 3, 2014 | 10:40 AM
jfall's Avatar
If the chicken lays golden eggs leave it alone.
At $1,200 an ounce you can then buy a new rover.
Don't drive it like this.
Could be the front drive shaft.
If that drops, your trouble will be a lot worse.
