Spacer between flywheel and flex plate?
Do all engines have a spacer between the flex plate and flywheel?
I was very meticulous when I disassembled the flex plate and flywheel. No spacer in between. There were only 3 pieces. Ring on the outside of the flex plate, flex plate, and flywheel.
‘04 D2 4.6.
I ask because I’ve seen reference to a spacer in an Atlantic British video.
Still have the engine out and just want to make sure all is good before installing it.
Thanks in advance.
‘04 D2 4.6.
Thanks in advance.
@Tony Luna That fat ring underneath ? I am pretty sure the 4.6 I tore down had that. I can check tonight
@Tony Luna I have a spacer the engine, it came out of was a 4.0 - I will get some pics for you tomorrow
