Spare tire
Old Aug 30, 2008 | 03:45 PM
AK Rover's Avatar
Default Spare tire
Will a 245/75r16 tire fit on the factory spare carrier?
Old Aug 30, 2008 | 03:53 PM
Default RE: Spare tire
Yes. The spare tire carrier doesnt care what size the tire is as long as the lug holes line up.
Old Aug 30, 2008 | 04:07 PM
AK Rover's Avatar
I was concerned that the taller tire would rest on the bumper and not allow the lug holes to line. Pulled my tire cover off for the first time since i bought the truck and found I have a brand new BFG all-terrain for a spare. Looks like it has never even touched pavement. The other tires are Bridgestone Dueler A/T. Not quite aggressive enough for me.
Old Aug 30, 2008 | 04:13 PM
I see what you were asking now. I did not think about that. I believe that there is a spare tire re-locating kit to to allow for bigger tires.
Old Aug 30, 2008 | 04:55 PM
llesra's Avatar
ive managed to fit a 285/75/16 tire on the back door of my d1
Old Aug 31, 2008 | 12:32 AM
Urban Panzer's Avatar
Its surprising how much bigger even a more aggresive tyre is when you hang one on the rear door. I have the Land Rover stainless lockable wheel cover, with my standard tyres (when i bought the car) the metal shroud around the tyre basically came all the way round and the 2 ends met itself in the middle, and the was about an 1 1/2" gap beteen that and the top of therear bumper.
I have now fitted General AT 2's all round, and whilst out on a trip I met a very nasty rock and destroyed one, so having to change to the spare (which was normal road tyre) I then tried to fit the cover back on the AT2, and it didnt fit !! doh!!!....
I since have had to modify the cover to fit the AT2's and now it literally clears the top of the rear bumper by 10 mm and where as the cover met itself at the bottom, there is now about a 3" gap.......so although the Grabbers are the same size 255/55 R18, they are actually considerably bigger because of the aggresive deeper tread on them...
Just a little nonsense info lol..........
Old Aug 31, 2008 | 01:00 PM
Willie 00D2's Avatar
I have a 2000 dII with new 245/75/16 BFG A/Ts. The spare tire rests on the rear bumper. I can feel it drag on the bumper a little when I open or close the rear door. I could drill the mounting holes so the tire mount would be higher but I think I will leave it like it is. I takes some stress off the door. These are heavy tires.
Willie
Old Aug 31, 2008 | 01:53 PM
Disco2Guy's Avatar
You can always flip the spare tire carrier if you need a little more room. I believe the center bolt (on the carrier) won't line up so a new hole should be drilled to line up with the existing hole on the door. Others have drilled the new hole in the door but I wouldn't want to do that. You'll also need to make a small notch so the wiper can rotate all the way.
mcbenavidez
Apr 7, 2006 07:00 PM
Petes 03 Rig
Dec 31, 2005 09:23 AM
socalrover
Oct 28, 2005 05:17 PM
AzCamel
Aug 5, 2005 06:45 AM
GadgetRick
Jun 19, 2005 10:57 AM
