Spares, What to save before junking?
Old May 26, 2020 | 04:08 PM
Best4x4's Avatar
Originally Posted by mollusc
MAF is a different diameter. The airbox is also different between the two years.
Radiators are cheap. I wouldn't bother with trying to harvest an old one.
Housing is different between a 4.0 & 4.6, but the actual sensor itself = same part.
Old May 26, 2020 | 04:10 PM
Best4x4's Avatar
I'd just remove the entire doors personally and keep them intact vs gut em. They simply unplug, then remove the check strap, and 2 clips per door and simply lift them off.
Old May 26, 2020 | 07:09 PM
Extinct's Avatar
  1. Sunvisor clips
  2. Door lock actuators
  3. Sunroof motors
  4. CPS
  5. MAF sensor as stated
  6. 02 sensors
  7. Hoses for spares
  8. IAC valve
  9. Purge valve
  10. Coils
  11. Wires
  12. Power steering pump (you can rebuild off the truck)
  13. Alternator
  14. Idler pulleys
  15. Master cylinder and brake booster
  16. ECU/BCU/Instrument cluster
  17. Steering wheel depending on condition
  18. Seat switches
  19. Rear bumper if you have the room
  20. Brake sensors if you are up for it.
  21. Tail door bezel
  22. Cowl panel
BTW, I need some Bahama Beige interior parts, if you feel like selling a few send me a PM or email.
Old May 26, 2020 | 07:46 PM
mln01's Avatar
I think the universal answer applies here --- it depends.
It depends on how much storage space you have. It depends on your appetite for dismantling. And it depends on your financial resources available to buy parts later that you'd otherwise send to the crusher now.
I'd focus first on high(er)-value parts that are more likely to fail. Here's my quick list. It presumes you don't have unlimited storage space. Otherwise, just keep the whole truck!
  • XYZ switch - Crazy-expensive new, and a known failure point
  • Alternator
  • Starter
  • Drivers door lock actuator
  • MAF sensor
  • Upper radiator hose T-fitting
  • Spark plug wires - Having spares is a good idea if they're decent and you already have them
All of this presumes you'll already strip the donor truck of any small bits and pieces your survivor truck is now lacking.
You'll find that some on this forum will advocate keeping A LOT more parts, and in the end it's up to you and your risk tolerances and physical constraints. I personally think some of the prior recommendations are overboard, but I respect that they are the personal recommendations of those forum members and that they are borne of the problems that have beset them with their trucks, as are mine. I hope this helps.
Old May 27, 2020 | 03:47 PM
Extinct's Avatar
XYZ switch is a good add. Starter is reasonable priced at Autozone, not sure I would put a used one of those back in as it is usually the brushes that wear out, especially one off a 99. As far as the upper hose Tee, I have a bucket full of those if anyone wants a spare or two - free if you pay shipping. They are useless after the inline mod and I refuse to drive a sell a truck without it.
Old May 27, 2020 | 09:15 PM
ahab's Avatar
If the AC worked it might be worth grabbing the condenser and the compressor. I would, hell, I did!
redwhitekat
Jul 26, 2018 05:43 PM
doxster22
Jun 13, 2017 05:56 PM
moglide
May 19, 2014 03:46 AM
Classic89
Feb 10, 2009 04:43 PM
Wickedzig77
Dec 22, 2006 12:14 AM
